Port security / cloud authentication record authentication failure log
Zyxel_Melen
Zyxel_Melen Posts: 4,651 image  Zyxel Employee
User @Dpj requires Nebula switch to record an authentication failure log when Port security / cloud authentication fails.
Anyone who also needs this log, please leave your comment and give this idea a vote.
Orignial post
Zyxel Melen
2 votes
Active · Last Updated
  • SkyGoat
    SkyGoat Posts: 41 image  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    Yes, I would also like this feature.
    Ideally I would like if the failed authentication devices could be presented in a table format somewhere within Nebula under the following headings:
    MAC Address, Manufacturer, Switch, Switch Port, First Seen Date, Last Seen Date
    And have the ability fo select the device and approve it / add to Cloud Authentication list, directly from that screen.
    If the device is still connected to a switch, it should remain in the blocked/pending table.
    If the device is disconnected from the switch, it should remain in the blocked/pending table for 30 days before disappearing.
  • scha
    scha Posts: 4 image  Freshman Member
    Zyxel Certified Network Engineer Level 1 - WLAN Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Switch
Nebula Tips & Tricks
