Reboot USG Flex GUI Access Only
Pook
Pook Posts: 153 image  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
edited April 2025 in Nebula
Hi Guys
I have a Flex 200 that has lost communication with Nebula NCC, the appliance is up and running ok though. It is not possible for anyone to gain access to pull the plug for a power cycle.
I can VPN on to the network ok and log in to GUI of the Flex but I do not see a reboot option anywhere in the options. Any ideas what I can do to reboot the appliance?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,586 image  Zyxel Employee
    Hi @Pook,
    I think you can try to SSH the device and use the command reboot.
    Zyxel Melen
Nebula Tips & Tricks
