VPN client-to-site settings for MacOS 15 (Sequoia)
Hi, I'm currently using these settings for a working VPN connection from Windows native clients:
Gateway:
- SA Lifetime: 86400
- Negotiation mode: Main
- Proposal (enc/auth): 3DES/SHA1
- Key Group: DH2
Connection:
- SA Lifetime: 3600
- Active Protocol: ESP
- Encapsulation: Transport (L2TP/IPSec) or Tunnel (IKEv2)
- Proposal (enc/auth): AES256/SHA1
- PFS: None
These settings have proven stable and widely supported in Windows' native VPN client and work for both L2TP/IPSec and IKEv2. I now have to connect a new Mac with macOS 15 (Sequoia) via VPN and I'm looking for a minimal change to the above settings in order for the native Mac client to successfully connect.
If anyone has the working settings for the newsest MacOS, please share. I cannot find the supported protocols for Sequoia anywhere online.
Thanks!
PS: I'd like to use the native client on the Mac (or a free alternative), not a paid VPN client.
Best Answers
For anyone interested, the native macOS 15 Sonoma VPN client works with the settings that I have posted. No need to do any adjustements, L2TP/IPSec with pre-shared key worked flawlessly.
Hi @MarkoD
Thank you for sharing your experience and the successful VPN settings for macOS 15 (Sonoma)!
To confirm, the default L2TP VPN setup using the Zyxel VPN wizard can indeed work with the following encryption settings:
- Phase 1: 3DES/SHA1/DH2
- Phase 2: 3DES/SHA1/None
Kay
Hi @MatteoFF ,
If you can't establish a VPN connection after updating to macOS Sonoma or macOS Sequoia, we recommend you refer to this article first.
If the issue still persists after configuring according to the article, please provide your remote session information so we can help check the problem remotely.Zyxel_Judy
USG60
Hi @MarkoD
Kay
Dear @Zyxel_Kay, you can bump up security by using SHA256 instead of 3DES in Phase 2. It works for built-in clients in Windows and also Mac.
Sorry ... but I entered the parameters you indicated and nothing works. I have the client-gateway connection but there is no packet traffic. I can't ping, connect to an internal website or to the NAS via SMB/AFP. Can you help me?
I tried disabling "Policy Route" but it doesn't change anything. With Microsoft Windows 10/11 everything works perfectly.
Whit IPSec IKEv2 of Mac, the connection don't start; whit Zyxel SecuExtender IPSec the connection start but there is no packet traffic. And this only happens on Mac.
Hi @MatteoFF ,
- 441 Beta Program
- 293 Service & License
