Gs1350-12hp force reset
Christzofdu69
Christzofdu69 Posts: 2  Freshman Member
Hello Just buy a occasion gs1350-12hp
After reset still cloud light is Green and default user and password doesnt work
How to force ?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,716  Zyxel Employee
    edited April 7 Answer ✓
    Hi @Christzofdu69,
    To factory default your switch, please press the restore button for 10 seconds.
    In addition, if the cloud light is stable green when you connect to your network with Internet, this switch is still registered on Nebula. Please ask your seller to remove it from his organization. Or, you can use Nebula APP to register to your org/site to let your switch run in Nebula mode.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Christzofdu69,
    Zyxel Melen
  • Christzofdu69
    Merci beaucoup ca fonctionne
