Wi-Fi access for 25 students for 1 hour
Hello, I work in a middle school, and I would like, for example, a class of 25 students to be able to connect to the Wi-Fi, but for a limited time of 1 or 2 hours. Currently, I'm using the Nebula NCC Free Pack. I was thinking of getting the Plus Pack license to access the vouchers, but apparently a voucher is only valid for 1 person, and creating 25 vouchers and then distributing them at the start of the class is too restrictive. What would be the most recommended method for connecting my 25 students for a one-hour class?
In my other college, it's Ubiquiti equipment, and there I am able to create 1 voucher for 25 people, for a chosen time, I don't think we know how to do the same thing with Zyxel vouchers?
Thank you for your interest.
Hi @Godinne ,
Currently, you only can configure the voucher (captive portal) to allow 1 to 10 users or set it to unlimited users for the SSID. So, you can consider setting it as "Unlimited"
You can set this up in the following location: Site-wide > Configure > Access points > SSID advanced settings > Captive portal advance setting
For step-by-step instructions on how to create a voucher for the SSID, please refer to this FAQ:
Zyxel_Judy
Hi @Godinne ,
Zyxel_Judy
Hi @Godinne ,
You can also refer to the SSID schedule feature on Nebula, which allows the SSID to broadcast only during specific times you configure—for example, every Monday from 8:00 to 9:00. However, please note that this feature does not limit the number of clients to 25 at the same time.
Let us know if this feature could be a suitable workaround for your requirement.
Zyxel_Judy
- 244 Nebula Ideas
- 6.9K Security
- 802 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 534 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
