On Nebula, how do I block an application category with an exception?
henriquev
henriquev Posts: 20 image  Freshman Member
Is there any way to block an application category like "media streaming" but allow Youtube?
The only way I managed to do is blocking everything one by one but leaving the youtube part out.. is that the only way?!
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @henriquev ,
    Thank you for your private message.
    We've identified that you're using the USG FLEX 200, which doesn't support the Forward action in Application Patrol on Nebula. Currently, this feature is only supported by USG FLEX H series devices.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @henriquev ,
    To meet your requirement, please add a rule to "Forward" the YouTube application above the rule that "Reject" all traffic in the Media Streaming category.
    The firewall processes rules in order, so it will apply the Forward rule for YouTube before reaching the Reject rule.
    Zyxel_Judy
    Untitled Image
  • henriquev
    Hi @Zyxel_Judy,
    My nebula does not have an option to change the action nor I managed to add two rows with the same category. Is there anything I need to enable to do it?!
  • Zyxel_Judy
    Hi @henriquev ,
    Let's add a rule to "Forward" the YouTube application first:
    1. Click on the Search Application combo box
    2. Find and select "YouTube", Action as "Forward"
    3. Click the Add button
    Then, add a rule to "Reject" media streaming applications:
    1. Click the Add button
    2. In the Category selection, choose "Media Streaming"
    3. Set the action to "Reject"
    Zyxel_Judy
    Untitled Image
  • henriquev
    hi, @Zyxel_Judy,
    The issue is my nebula does not have an option to "forward" there is no option to change the reject as you can see in my screenshots.
    Beside that, If I try to add two of the same category, Nebula aggregates them into one.
  • Zyxel_Judy
    Hi @henriquev ,
    For more assistance with your case, please enable Zyxel support and provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message. By the way, please allow us add/ modify rules according to your specific needs.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @henriquev ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
