On Nebula, how do I block an application category with an exception?
Hi @henriquev ,
Thank you for your private message.
We've identified that you're using the USG FLEX 200, which doesn't support the Forward action in Application Patrol on Nebula. Currently, this feature is only supported by USG FLEX H series devices.
Zyxel_Judy
Hi @henriquev ,
To meet your requirement, please add a rule to "Forward" the YouTube application above the rule that "Reject" all traffic in the Media Streaming category.
The firewall processes rules in order, so it will apply the Forward rule for YouTube before reaching the Reject rule.Zyxel_Judy
Hi @Zyxel_Judy,
My nebula does not have an option to change the action nor I managed to add two rows with the same category. Is there anything I need to enable to do it?!
Hi @henriquev ,
Let's add a rule to "Forward" the YouTube application first:
- Click on the Search Application combo box
- Find and select "YouTube", Action as "Forward"
- Click the Add button
Then, add a rule to "Reject" media streaming applications:
- In the Category selection, choose "Media Streaming"
- Set the action to "Reject"
Zyxel_Judy
hi, @Zyxel_Judy,
The issue is my nebula does not have an option to "forward" there is no option to change the reject as you can see in my screenshots.
Beside that, If I try to add two of the same category, Nebula aggregates them into one.0 -
Hi @henriquev ,
For more assistance with your case, please enable Zyxel support and provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message. By the way, please allow us add/ modify rules according to your specific needs.
Zyxel_Judy
Hi @henriquev ,
Zyxel_Judy
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
