Nebula App shows different Security Alert hits number
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited April 2025 in Nebula
Hello everyone,
I went online to check an Organization:
and I see that the Nebula webpage shows zero Security Alerts and 81 CDRs:
while the Nebula App shows 7 Security Alerts:
So I think that something is not working properly here.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Update:
    Nebula dashboard has applied this change.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    The "Security Alert Detected" on the Nebula app is the same as the "Security Alert" on the Nebula dashboard. The current difference is that one reference shows the last 7 days, and the other shows the last 24 hours. However, displaying the last 24 hours is weird(too short). I will check with our team to see if this is an issue.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_MarkV
    I suggest to change it to 7d value, like th CDRs counter
  • Zyxel_Melen
    Hi @GiuseppeR,
    After checking with our team, we will change it to 7 days as the CDRs counter and the Nebula APP. I will update you once this improvement has been implemented.
    Zyxel Melen
  • Zyxel_Melen
    Update:
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    I can confirm that sync between the webpage:
    and the app:
Nebula Tips & Tricks
