Nebula SecuReporter - missing devices' names
GiuseppeR
GiuseppeR Posts: 530 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I cannot see a lot of names inside my Organization & Device area of SecuReporter.
As you can see I read only few of them:
Is there a specific reason?
How can I fix it?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @GiuseppeR ,
    The device name displayed in SecuReporter corresponds to the device name registered in your MyZyxel account.
    Please check your device name in MyZyxel and enter the exact same name if you want it to appear in SecuReporter.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Zyxel_Judy
    Untitled Image
  • GiuseppeR
    Hello @Zyxel_Judy
    is it possible to sync that value with the same name that is assigned in Nebula NCC?
    So only on premise firewalls have to be renamed manually.
    Thanks a lot
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Currently, there is no feature to sync device names from NCC to SecuReporter. Please manually rename the devices on MyZyxel.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
