[Release Note] Nebula Control Center - 19.00 software Release!
Zyxel_CSO
Zyxel Nebula Control Center Release Note
Common NCC (Organization,Site-wide,etc.):
- Enhance the UI/UX for MSP Cross-Org synchronization to make it clearer and easier to use. (Nebula MSP Pack license is required)
- Improve banner UI/UX to let eligible org enable NCC Pro easily.
Wireless LAN (WLAN):
- Added WiFi Alert Insight Widget in Dashboard. (Nebula Pro Pack license is required)
Switching:
- Support new Switch series. The XS1935 series is added to Nebula in this release.
- Simplified the PoE 7 power-up mode options to a standard, compatible design for easier use. First available on the XS1935 series and upcoming PoE models.
Security Firewall:
- Added VTI and LAG interface for USG FLEX H series.
- Added Service and Schedule object for USG FLEX H series.
- Added Configure Security policy for USG FLEX H series.
- Added Configure Policy route and Static Route for USG FLEX H series.
- Added Configure NAT for USG FLEX H series.
- Added DNS, DDNS, Authentication Server and SIP ALG Firewall settings for USG FLEX H series.
- Site-to-Site VPN is enhanced. Nebula SD-VPN helps to ease the configuration the most if the devices are all managed by Nebula. "Non-Nebula VPN" is now renamed to "Auto-Link VPN", and "Manual-Link VPN" has been added for manual VPN setup exclusively for the USG FLEX H series.
- Added Clients and Application usage monitoring for USG FLEX H series.
- Dashboard now supports Firewall status and Application usage for USG FLEX H series.
- Support Secure WiFi License for USG FLEX H series.
Security Router:
- N/A
Mobile Router:
- N/A
Accessory enhancements:
- N/A
Zyxel Nebula Support
Nice to see there are more options now for configuration!
But also i found a few bugs
Under Configure/Object → Service (Beta)
When i click +Add, it doesn't respond
———————————————————————-When i go to Address, i can click the add button, and the next row appears, but i cannot click Save. ———————————————————————-Further what i miss: Captive portal. When you have the USG Flex 200 you have an option captive portal. I don't see it hereyours dennis0 -
it seems also here has something changed…. with layout.
One point allready solved…. The add button does respond, but the new entries appears on the last page. Not so intuitive in my opinion
yours dennis
Hi @Dpj,
Will it be good if the web page automatically changes to the last page when adding new entries?
Zyxel Melen0 -
The lay-out thing had to do with my device it seems. Looks ok now
- 440 Beta Program
- 292 Service & License
