Nebula Cloud Service Incident 2025-04-14 09:22 ~ 11:10 (UTC+0)
Dear Nebula Users,
The system had some issues due to an incident.
Issue Started from:
2025-04-14 09:22 (UTC+0)
Resolved:
2025-04-14 11:10 (UTC+0)
Issue Symptom & Risk:
- (Resolved) Some pages are unable to load successfully. Refreshing the page will help to load the data.
- (Resolved) The pages that relate to the H series's application usage will be temporarily unavailable. We will update you once it is available.
Resolved time:
2025-04-15 07:10 (UTC+0)
Note: This incident does not affect Nebula devices and their local network services if there is no any configuration change.
If you observe any issues that do not match the symptoms & risks mentioned above, please contact @Zyxel_CSO
We apologize for any inconvenience this has caused.
Zyxel Nebula Support
Dear Nebula users,
Update:
The loading issue has been solved.
Resolved:
2025-04-14 11:10 UTC+0
Note:
- The pages that relate to the H series's application usage will be temporarily unavailable. We will update you once it is available.
Zyxel Melen0 -
Dear Nebula users,
Update:
- The pages that relate to the H series's application usage are available.
Update/resolved time:
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
