Nebula Cloud Service Incident 2025-04-14 09:22 ~ 11:10 (UTC+0)
Zyxel_CSO
Zyxel_CSO Posts: 481  Zyxel Employee
5 Answers First Comment Friend Collector Eighth Anniversary
Dear Nebula Users,
The system had some issues due to an incident.
Issue Started from:
2025-04-14 09:22 (UTC+0)
Resolved:
2025-04-14 11:10 (UTC+0)
Issue Symptom & Risk:
- (Resolved) Some pages are unable to load successfully. Refreshing the page will help to load the data.
- (Resolved) The pages that relate to the H series's application usage will be temporarily unavailable. We will update you once it is available.
Resolved time:
2025-04-15 07:10 (UTC+0)
Note: This incident does not affect Nebula devices and their local network services if there is no any configuration change.
If you observe any issues that do not match the symptoms & risks mentioned above, please contact @Zyxel_CSO
We apologize for any inconvenience this has caused.
Zyxel Nebula Support
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,759  Zyxel Employee
    edited April 14
    Dear Nebula users,
    Update:
    The loading issue has been solved.
    Resolved:
    2025-04-14 11:10 UTC+0
    Note:
    1. The pages that relate to the H series's application usage will be temporarily unavailable. We will update you once it is available.
    Zyxel Melen
  • Zyxel_Melen
    Dear Nebula users,
    Update:
    1. The pages that relate to the H series's application usage are available.
    Update/resolved time:
    Zyxel Melen
