NR7102 - Set eth1 interface speed manually
liongoldfish
Is there possibility to set the eth1 interface speed manually?
Getting following in the logs even if the up level switch is fixed 1Gbsp (about 10sec in the logs)
esmd: Interface: eth1, Status: Down
esmd: Interface: eth1, Status: Up, Speed: 1000, DuplexMode: Full
esmd: Interface: eth1, Status: Up, Speed: 100, DuplexMode: Full
Probably some issue with the cabling, but should be able to force the 1G on the interface. Unfortunately I can't find any setting to force this.
Hi @liongoldfish,
This is not supported on NR7102
- 211 Nebula Ideas
- 544 USG FLEX H Series
- 341 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 465 News and Release
