Nebula App shows different Security Alert hits number
Update:
Nebula dashboard has applied this change.
Zyxel Melen0
Hi @GiuseppeR,
The "Security Alert Detected" on the Nebula app is the same as the "Security Alert" on the Nebula dashboard. The current difference is that one reference shows the last 7 days, and the other shows the last 24 hours. However, displaying the last 24 hours is weird(too short). I will check with our team to see if this is an issue.
Zyxel Melen0 -
Hello @Zyxel_MarkV
I suggest to change it to 7d value, like th CDRs counter
Hi @GiuseppeR,
After checking with our team, we will change it to 7 days as the CDRs counter and the Nebula APP. I will update you once this improvement has been implemented.
Zyxel Melen0 -
Update:
Zyxel Melen0 -
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
