NAS 326 change disks
2»
  • gyulav
    gyulav Posts: 10 image  Freshman Member
    edited April 2025
    In fdisk it has an error:
    "GPT PMBR size mismatch (3907029167 != 3519069871) will be corrected by w(rite).
    The backup GPT table is corrupt, but the primary appears OK, so that will be used.
    GPT PMBR size mismatch (3907029167 != 3519069871) will be corrected by w(rite)."
    Parted was fixed this error:
    (parted) print list
    Error: The backup GPT table is corrupt, but the primary appears OK, so that will
    be used.
    OK/Cancel? OK
    Warning: Not all of the space available to /dev/sda appears to be used, you can
    fix the GPT to use all of the space (an extra 3907008000 blocks) or continue
    with the current setting?
    Fix/Ignore? Fix
    Now fdisk delete/re-create partition is OK. :)
    Reboot NAS.
    /proc/partition show new larger size.
    resize2fs: … on-line resizing required
    old_desc_blocks = 117, new_desc_blocks = 233
    resize2fs: Permission denied to resize filesystem
    I think: i must unmounting (hard) and stop device.
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    Or partition delete with fdisk is not needed?
    Yes it is. mdadm doesn't 'know' anything about the block device below it. So it cannot resize the containing partition.
    And the filesystem is not Linux RAID, but Linux filesystem.
    That doesn't actually matter. It's just a label in the partition table. The partition itself is just a bunch of sectors, and at least in an MBR partition table it's completely ignored by Linux. I think it's also ignored in a GPT table. In any case it can be easily changed.
    It did not work.
    That is strange. It ought to work. I wonder if the implementation of fdisk on the NAS can only deal with 32 bit sector addresses? Does /proc/partitions show a 4TB sda?
    If yes, try parted.
    parted /dev/sda
    print
    resizepart
  • gyulav
    Thanks, and sorry. I did not fix/improve previous post understandably.
    fdisk and grow is OK.
    Only resize is problem.
    "resize2fs: … on-line resizing required
    resize2fs: Permission denied to resize filesystem"
    I think: i must unmounting (hard task) and stop device. Then i must run e2fsck.
  • Mijzelf
    edited April 2025
    You must unmount the filesystem (/dev/md2, I suppose), but not stop it. If you stop it, the md device is gone, and only /dev/sda3 is left. But that doesn't contain a filesystem.
    Then run e2fsck on /dev/md2.
  • gyulav
    @Mijzelf : Thanks.
    It is work.
