DX3301-T0 Telnet
I have just installed a new DX3301-TO. When I try and access by ssh I get the incorrect host key message. When I try and telnet in it refuses to connect. In Maintenance > Remote Management telnet is not listed.
How do I install a correct host key and how do I add telnet for remote maangement, please?
Telnet is activated by default (only via local Lan) but you cannot configure it in the menu section, you can try this and check out if you make a fault using your SSH client .
But i revieved this and i forgot that i activated telnet (and ftp too) by changing the exported config file in the ftp and telnet section and then reimported it by adding a value in the line ["Mode":"LAN_withoutWL",]which was empty before like this ["Mode":"",] !
Sorry for the delay in getting back to you. Been away for a few days. Busy at the moment but will try the config file hack when I get the time to sit down and work things through.
Thanks for the help.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
