Allowing WAN to LAN traffic via a ZYXEL EX3301-T0
BrownianBridge
BrownianBridge Posts: 2 image  Freshman Member
edited April 2025 in Home Router
I am trying to communicate with a device on my LAN from the internet.
I have a static IP, and the IP listed on my routers GUI matches that visible from the internet (for example, via a 'find my ip' service).
I have attempted allowing Ping access to my network. I have:
  1. Created three Protocols:
    a) Name: PingTest
Ports/Protocol Number: ICMP: 0 /Echo-reply
b) Name: PingBack
Ports/Protocol Number: ICMP: 8/Echo-request
2. Added Access Control List Rules:
a) Source IP: Any/32
Destination IP: Any/32
Service: Ping
Action: ACCEPT
b) Source IP: Any/32
Service: PingBack
Action: ACCEPT
I expected the above to allow ping interaction from the internet to my routers IP. When I ping my routers IP, I receive no response. 100% packet failure.
Could I please ask what I am missing ?
Cheers.
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    You need to check whether "PING" is enabled in the settings on the remote management page.
  • Peter2
    Peter2 Posts: 176 image  Master Member
    I think first you need a port forwarding for the special needed service of this LAN device and then you can test it with a ping to these ports from outside WAN .
  • BrownianBridge
    Thankyou Liba. Unfortunately, the 'remote management' section, as mentioned in the Zyxel help manual, is not accessible in my routers GUI.
  • awm22
    awm22 Posts: 3 image  Freshman Member
    Any further joy on this? similar issues and lack of progress for the EX5601-T0
    As @BrownianBridge did, I setup the protocols for ICMP echo request and reply; added ACLs for this (not actually sure if I wanted WAN to ROUTER or WAN to LAN so tried each, without joy)
    Has anyone (with the under-norished router GUI/ssh) got tcpdump to work? its a command thats listed but I can't get it to run. (some sort of nailed down syntax I'd guess.)
