FWA710 - get information about LTE signal via webapi or ssh
Is there any possibility to get information about LTE cell info ( RSSI, etc… ) via SSH, SNMP or web api for Zyxel FWA710 ?
Hi @marianob85
Thank you for reaching out!
Yes, you can obtain LTE cell information (e.g., RSSI) via SSH on the FWA710. Here's how:
- Enable SSH access through the web configurator by navigating to Maintenance > Remote Management > MGMT Services and enabling SSH.
- Once SSH is enabled, access the device using an SSH client and run the following command to retrieve cell information:
ZySH> cfg cellwan_status get
Regarding SNMP, the FWA710 does not support this feature for LTE cell information. Similarly, the Nebula API currently supports monitoring the online/offline status of Nebula mobile router devices but does not provide LTE cell details.
Let us know if you have any further questions!
Kay
Hi @marianob85
Kay
Oo. I hadn't thought to look for such information if cfg section.
Works like a charm. Thanks!
is there a list of all cli commands for the FWA710 anywhere?
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
