2 AP stopped working with GS1900-24EP
SwitchAnon
SwitchAnon Posts: 3  Freshman Member
Two of my access points (Unifi) have no internet when plugged in to the switch GS1900-24EP. It used to work just fine. I have three more AP's that works fine with the switch.
How can I fix this problem?
Information:
Switch: GS1900-24EP
Firmware: 2.7.3
My AP's have worked perfect for years with the switch.
The AP's works great if plugged into the router (no switch).
I have reset the AP's.
POE power and cables is not a problem.
It does not matter if I change the port and cables.
When plugged into to the switch I will get internet for about a minute and then it "shuts down" (no or super slow internet).
The AP have the right MAC address and I can't see any duplicates in the switch web UI (MAC table).
The port status is, State: Enable, Up, Auto-1000M.
Any ideas?
