Suitable repeaters for Nebula FWA510
A new question about suitable repeaters. According to the manual and what I've read here at Community, the Nebula FWA510 lacks support for Easymesh. I need a repeater with two Ethernet ports for connecting devices and another to amplify my wifi outdoors. I can't find anything on the Swedish market that I can see obviously working with the Nebula FWA510. What should I choose?
Best Answers
Hi @Hille ,
The Nebula FWA510 doesn't support Easymesh, but we can recommend the best suitable network topology with Zyxel device as below:
- Connect either the WAC500H or WAX300H to your Nebula FWA510 using an Ethernet cable. Both these models feature multiple LAN ports for your wired connections.
- For outdoor coverage, the NWA55AXE can wirelessly connect to either the WAC500H or WAX300H using the smart mesh technology, eliminating the need for additional cabling to your outdoor areas.
Zyxel_Judy
0 - Connect either the WAC500H or WAX300H to your Nebula FWA510 using an Ethernet cable. Both these models feature multiple LAN ports for your wired connections.
Hi @Pulla,
Sorry for the late reply!
Since the FWA510 does not support the mesh feature, a wired connection to the downlink AP is required, as illustrated in the topology shown in Judy’s previous reply. In other words, the FWA510 cannot connect wirelessly to any repeater or extender devices.
Zyxel Tina
Hi @Hille ,
Zyxel_Judy
Is there repeater/extender that works wirelessly with FWE510. Ethernet ports are not must in thia case.
WX3100-T0 perhaps?
Hi @Pulla,
Zyxel Tina
I think this would work
WX3100-T0 | Dual-Band Wireless AX1800 Gigabit Access Point/Extender | Zyxel Networks
WDS is not supported on FWA510 but a AP that can connect as a client to FWA510 should work
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
