px3321-t1 ethernet port as wan
Gabrieltito234
Gabrieltito234 Posts: 3  Freshman Member
I have a PX3321-T1 I found on the street, it's working well and I wanted to use as the main router, but there is a problem, my isp has a pon mac filter that only allow the pon they installed to be connected.
So I only have two options: change the pon mac address or use one of the ethernet ports as a wan to connect to the internet.
Is there a way of doind this?
  • Gabrieltito234
    I also found this command in ssh: sys atgs <GPONVendorID> <GPONSerialNumber> but it only says "Access denied!"
  • Peter2
    Peter2 Posts: 174  Master Member
    edited May 7
    I think you have to register this device replacing your first registered device , there only can be one device registered over the ISP . It is shared medium and so only one correct user device has to be adressed .
    The device seems to have no WAN Port extra , you can look if it is possible configure in the broadband section an new WAN connection type "Ethernet" "ETH" sometimes it is possible to replace a WAN port with a normal Ethernet port mostly Lan1 . If this is possible you could use it as a external firewall Wlan Router with any type of Modem not only Gpon ONT .
  • Gabrieltito234
    The only way I found to use it here was disabling DHCP and using it as a secondary router, but I wanted to use it as a primary router but there is no option to use ethernet as wan, only gpon
