2 AP stopped working with GS1900-24EP
2»
    PeterUK Posts: 3,999  Guru Member
    So you connect a new AP in the same place as the two AP's that don't work and it works?
    That seems odd the switch looks to be working fine.
    But then I don't get why the AP's work fine without the switch maybe its something to do with Unifi Cloud Key that the AP can't talk to it?
  • SwitchAnon
    SwitchAnon Posts: 7  Freshman Member
    Indeed, ut's such a wierd problem. The Cloud Key can talk to the AP just fine if I connect another Zyxel switch (GS1005HP).
    Router > Technicolor TG799vn v2 / Unifi Cloud Key 2 > Zyxel Switch GS1900 > AP = NOT WORKING
    Router > Technicolor TG799vn v2 / Unifi Cloud Key 2 > Zyxel Switch GS1005HP > AP = WORKING
    Any ideas?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,724  Zyxel Employee
    Hi @SwitchAnon,
    Thanks for sharing the topology. Could you share more details like: which switch port connects to AP and which port connects to Technicolor TG799vn v2 / Unifi Cloud Key 2 or router?
    And this issue is that the some AP can't communicate with Technicolor TG799vn v2 / Unifi Cloud Key 2? Can the AP wireless client access Internet?
    Zyxel Melen
