NAS540 don't boot
WelD
WelD Posts: 2
edited March 2024 in Personal Cloud Storage
Good day.My friend gave me a nas540. NAS stopped starting. When I try to turn on the power indicator, the fan turns on at high speed for a second, then the cooling fan starts spinning slowly. Only the power light is on. There is no reaction to the reset button.
I connected uart. The log is shown in the screenshot.
Does anyone have any idea what can be done?
Thank you
  • Mijzelf
    Mijzelf Posts: 2,961  Guru Member
    This is one of the cases where "if you have to ask, it's not for you" can be applied.
    This box has a 3 stage bootloader. The CPU has some loader code build in, which is just smart enough to read and execute code from SPI flash. This is the 2nd stage 'uloader' you see. The uloader does some initialisation, and then loads barebox (3th stage) from SPI flash in memory, and starts it. Here the box stalls, and some watchdog kicks in and reboots the box, or barebox itself decides to reboot, or some illegal code causes a reboot.
    In all cases probably barebox is damaged in the SPI flash. The solution would be to desolder the SPI flash from the motherbord, put it in a SPI programmer, reflash barebox, and solder it back. Maybe the reflashing can be done while the chip is still on board, but in that case you'll have to localize the ISP pins or pads.
    If you want I can provide a dump of the barebox partition, but for the rest I can't help you. A few years ago I was not even able to localize the SPI chip. https://web.archive.org/web/20180720225145/http%3A//zyxel.nas-central.org/wiki/PCB_Photos_%28NAS540%29
    BTW, the function of barebox is to load and execute the Linux kernel from NAND flash.
  • WelD
    WelD Posts: 2
    Thank you for your reply. Quite a complex and non-standard breakdown. A small clarification. Repetition in the log is not a reboot, but a power on. That is, when the server is turned on, the log reaches "##Starting Barebox at 0x01000000" and does not go further, no matter how much time passes.
  • lesik1988
    lesik1988 Posts: 4  Freshman Member
    This is exactly the problem. Send spi image. Thank you.
  • Mijzelf
    I can provide you that, I think, but you have to be patient. I'm in a renovation and have no access to my NAS. I think until the begin of June.
  • lesik1988
    Thank you, I'm looking forward to it)
  • lesik1988
    Good afternoon. I remind myself. Thank you.
  • Mijzelf
    Today I got a box from storage, and I still don't have my NAS540, but I have my NAS520 back now. I think the 2nd stage bootloader is identical, as according to 'strings' it contains the same timestamp (uloader 2011.06.0 (May 20 2014 - 16:36:41)) as the one from NAS540.
    Anyway, I PM'ed you a download link.
  • lesik1988
    Thank you for the file, but it only contains the uloader part, which is exactly the same as mine.
    SPI:
    0x000000000000–0x000000040000 : "uloader"
    0x000000040000–0x0000000c0000 : "barebox"
    0x0000000c0000–0x000000100000 : "env"
    My issue is specifically with barebox.
    The logs show that barebox is copied from SPI but does not start.
    You only sent the uloader part. As I understand it, my problem is with barebox.
    Please send the full image.
  • stein_990
    stein_990 Posts: 33  Freshman Member
    edited August 25
