Reset NWA55AXE
GrumpyBruno
GrumpyBruno Posts: 1 image  Freshman Member
How can i do a factory hardware reset on NAA55AXE? I recently bought an ‘open box’ and now regretting it since the device was registered in the store where it was ex-display from. When I add this to Nebula it just states it as offline all the time even though the green LED is on and seems to be receiving data. When on I have another WiFi network available as ‘Zyxel’ but it is password protected so I cannot access it. Wanted to do a reset so I can connect it my site, but all rests seem to be software based which i cannot initiate since my account doesn’t recognise it as connected.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    Hi @GrumpyBruno,
    It is possible that the inability of your NWA55AXE to connect to Nebula under your network and apply the new settings is a result of the previous owner configuring a static IP address for the device.
    As the NWA55AXE is designed as a durable, weatherproof outdoor access point, it is important to note that it does not incorporate a hardware reset button in order to maintain its waterproof performance.
    Here is the way to factory default it:
    1. Connect the AP (NWA55AXE) to a Zyxel PoE switch (e.g., GS1920 or XS1930) that supports Ethernet Neighbor.
    2. Access the switch's GUI and navigate to the Status page > Neighbor link.
    3. From the "Switch Neighbor" page, use the reset button to reset the Access Point.\
    Hope it helps.
    Zyxel Melen
