Activate SNMP on NR7302?
max93776
max93776 Posts: 3 image  Freshman Member
Hi, is there a way to activate snmp on nr7302? There is no option in the webui but zysh shows that there is a setting.. zysh is too buggy though. A simple snmpwalk showed no reaction
  • ohne
    ohne Posts: 1 image  Freshman Member
    First Answer First Comment
    SNMP ist not installed. You would have to gain root and install the package/add the binary.
