NR7101 - I’m missing some parts
I’ve got a NR7101 second hand, however it came bare.
A) The clear waterproof cover with the screws for the sim slots was missing.
B) The black plastic screw-in cable gland grommet assembly is missing.
C) I have no brackets
I've tried contacting the parts department but no response yet.
Any ideas where I can get these parts from? The most critical are the clear sim cover and the black cable gland fixing.
I’ve looked online and can’t find much to help. Any ideas people?
Original cable gland M25*1.5 with a 6 mm hole.
Alternative M20 or M16 with a reducing sleeve between your unit and gland.
I saw a bracket that probably fits but i´m not sure.
Thank you Selberg!
The centres of the bracket are 70mm between left and right and 67mm between top and bottom. I'll see what I can do.0 -
Hey Markys, did you manage to get the sim cover? I’m also missing one and cannot find it anywhere.
/j
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
