Can users be redirected to my website on connection?
Hi @mitrije,
To acheive your purpose, you can use captive portal function with to promotion URL after the captive portal page. Here is the reference FAQ:
In addition:
- Since this needs AP to support captive portal function, which is not supported on NWA50AX, we recommend choosing NWA90AX for this requirement.
- To configure captive portal for your SSID, you may reference this FAQ, it has a complete configuration flow. However, please note that you can use "Click-to-continue" in the Sign-in method for your purpose instead of Nebula cloud authentication.
Zyxel Melen0
Hi @mitrije,
In addition:
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
