Strange widget values: "Access points by usage" VS. "Access point clients by usage"
GiuseppeR
GiuseppeR Posts: 444  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited May 21 in Nebula
Hello everyone,
I have a site with a security router + 2 APs.
If I look at these two widgets I see huge difference in value:
Both of them are summarizing last 24h but on the left you see only 7 MB of usage.
Does "access point by usage" include also traffic spent via security router?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,635  Zyxel Employee
    edited May 22
    Hi @GiuseppeR,
    Access point by usage isn't include the wireless traffic on security router.
    Comparing with our field trial network's dashboard, it is strange that the Access points by usage > Traffic value is smaller than the top of client in Access point clients by usage.
    May I know if the issue remains? If so, please help to enable Zyxel support access, we will access to check this issue.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    yes it persists:
    I sent you the remote access via PM
  • Zyxel_Melen
    Hi @GiuseppeR
    Since your topology is USG Lite 60AX as mesh root and NWA50AX PRO as mesh repeater, this will cause the Access points by usage widget displays less than expected.
    After checking, this is the "Access points by usage" widget only trace the traffic passing the uplink. If the traffic is between the same AP same SSID or the AP uplink is USG Lite 60AX (mesh root), the traffic will not be recorded in this widget.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    do you plan to fix that detail considering USG 60AX mesh capabilities?
    It could be useful to read that value properly, like if the AP was going to internet via RJ45 and not via mesh
  • Zyxel_Melen
    Hi @GiuseppeR
    Yes, we have this in our feature request list.
    Also, I create an idea post. We will monitor the comments and vote to evaluate this idea.
    Display correct value in Access points by usage widget when APs are USG Lite 60AX's mesh repeator — Zyxel Community
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    thanks a lot for this update. I liked the idea post too, of course.
Nebula Tips & Tricks
