NR7103 - Flashing firmware
I have NR7103 from mobile operator. I cannot login to the administration. I think that they have some special custom firmware because im also unable to factory reset the device. I tried to reset it, but both LEDs started fo flash quickly and afterwards im still not able to login into administration. I also tried supervisor account, but it is telling me that supervisor account is disabled. Also wifi is disabled on the router and i cannot start it. So there is question if it is possible to reflash somehow the firmware? This device has also USB C port but i did not find any application how to configure the router through USB C cable.
Thanks a lot for any tips.
anyone flashed the operator nr7101 with standard Zyxel fw?
I can not get access to the admin panel on my operator variant. And would like to configure some settings
Hello. I also have this problem. Were you able to get the access codes to the device? Thanks.
I also have this problem. NR7303.
- 441 Beta Program
- 294 Service & License
- 461 News and Release
