Security concerns after device highjacked.
10megaton
10megaton Posts: 3 image  Freshman Member
I have two nwa50ax pro access points registered in Nebula. As I am away for a few days I left one powered off and the other online.
Today I discovered that somehow the access point that was left on has been highjacked and configured with many open wifi networks allowing unrestricted access to my LAN (see attachment).
How the hell is this possible? Even if someone has the details on the bottom of the access point (QR, MAC, serial) how can they add it to an alternative nebula account without being on the same LAN as the the access point itself?
As I now have no faith in Nebula security I have powered off both devices until Zyxel can explain what has happened.
This is terrible security and totally unfit for use.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,316 image  Zyxel Employee
    Thank you for your suggestion about making ownership override prevention enable as the default setting.
    From a pure security perspective, your suggestion makes complete sense. However, our current disabled default setting addresses a significant operational challenge we've observed in the field - a large number of customers who purchase used Nebula devices cannot register them when the previous owner hasn't properly deregistered the device first.
    I'll make sure to pass your feedback to our product team to evaluate this suggestion.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @10megaton ,
    The Nebula mobile app includes a feature that allows users to register access points using the Nebula QR code over the internet, without requiring a local network connection. This is a Nebula feature that enables users to register and manage your Nebula devices anywhere, anytime. This functionality serves two main purposes:
    1. Users don't need to manually enter the MAC address and serial number when the device is in unregistered status.
    2. Users can register previously used devices even when the original owner forgets to unregister the device from their account.
    We also provide a feature that allows users to prevent other users from scanning their device's Nebula QR code to register the device, addressing security concerns.
    For your case, it appears that someone has used your NWA50AX PRO's Nebula QR code to register your access point to their account. If you have the NWA50AX PRO device with the QR code, you can deregister the AP using the NCC Mobile App. For step-by-step instructions on this process, please refer to Part 1 of this FAQ.
    How to register Access Point to Nebula — Zyxel Community
    After deregistering the device, follow the steps outlined in this guide to prevent unauthorized device ownership override by other users.
    How to prevent device ownership override by other user — Zyxel Community
    Zyxel_Judy
    Untitled Image
    edited June 2025
    Maybe someone knows you login to Nebula?
    check if any other IP has logged in
    Zyxel Nebula - Recent logins
    I'm not sure if someone knows your wifi password they can then config your AP when in Nebula by standalone? or may be the AP reset to defaults which would of made it open?
  • 10megaton
    Thank you did the reply.
    When I try to re-register the device on the Nebula portal I get the "this device is locked by the device owner" error.
    Also the prevent device override should be the default behaviour for security reasons. It's madness that anyone with the details can take over the device by default.
  • Zyxel_Judy
    edited June 2025
    Hi @10megaton ,
    To better assist you, please check the community inbox for further discussion.
    Note that: Other users just can register your device if they have the device's Nebula QR code and you haven't enabled the feature to prevent device ownership override by other users.
    Zyxel_Judy
    Untitled Image
  • 10megaton
    Ok thanks but like I said, if you are serious about security prevent device ownership override would be enabled by default and you really need to change this .
  • Zyxel_Judy
    We have successfully helped you unregister the NWA50AX PRO from the other account, and we can confirm that you have now registered the device to your own account.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
