NCC account
Alab2025
Alab2025 Posts: 7  Freshman Member
Hi, I created my account using Google authentication.
Now I would like to use the same Google email but with a dedicated password, as I understand that signing in with Google may have some limitations.
How should I proceed?
Thanks!
  • Zyxel_Tina
    Zyxel_Tina Posts: 189  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 50 Answers First Comment
    Hi @Alab2025,
    Thanks for reaching out!
    We understand your request and would like to better assist you. Could you please let us know if there’s a particular reason or limitation that makes you want to switch from Google authentication to a password-based login using the same email address?
    Please note that this type of login method change is not available via self-service at the moment.
    Zyxel Tina
  • Alab2025
    Good morning Tina,
    The reason for my question is that I seem to recall reading somewhere (I can't remember if it was a post or the FAQ) about certain limitations when managing NCC if accessing with a Google account. However, if you can confirm that there are no such limitations, I will continue using my Google account to log in.
    Thank you.
  • Zyxel_Tina
    Hi @Alab2025,
    Thanks for your follow-up!
    After reviewing your concern and referencing our official guide on Enhancing Security with 2FA Enforcement in Nebula, I assume the limitation you were recalling might be this:
    The only known limitation is that Google and Apple sign-in methods are not compatible with Nebula's Organization-wide 2FA enforcement.
    This means if your organization chooses to enforce 2FA for all admin accounts, Google login accounts will not be able to meet that requirement and therefore won't be usable under that policy.
    So unless you plan to enable 2FA enforcement, you can continue using your Google account to access NCC without any issue or restricted functionality.
    Zyxel Tina
Nebula Tips & Tricks
