NAS540 don't boot
Good day.My friend gave me a nas540. NAS stopped starting. When I try to turn on the power indicator, the fan turns on at high speed for a second, then the cooling fan starts spinning slowly. Only the power light is on. There is no reaction to the reset button.
I connected uart. The log is shown in the screenshot.
Does anyone have any idea what can be done?
Thank you
This is one of the cases where "if you have to ask, it's not for you" can be applied.
This box has a 3 stage bootloader. The CPU has some loader code build in, which is just smart enough to read and execute code from SPI flash. This is the 2nd stage 'uloader' you see. The uloader does some initialisation, and then loads barebox (3th stage) from SPI flash in memory, and starts it. Here the box stalls, and some watchdog kicks in and reboots the box, or barebox itself decides to reboot, or some illegal code causes a reboot.
In all cases probably barebox is damaged in the SPI flash. The solution would be to desolder the SPI flash from the motherbord, put it in a SPI programmer, reflash barebox, and solder it back. Maybe the reflashing can be done while the chip is still on board, but in that case you'll have to localize the ISP pins or pads.
If you want I can provide a dump of the barebox partition, but for the rest I can't help you. A few years ago I was not even able to localize the SPI chip.
BTW, the function of barebox is to load and execute the Linux kernel from NAND flash.
Thank you for your reply. Quite a complex and non-standard breakdown. A small clarification. Repetition in the log is not a reboot, but a power on. That is, when the server is turned on, the log reaches "##Starting Barebox at 0x01000000" and does not go further, no matter how much time passes.
This is exactly the problem. Send spi image. Thank you.
I can provide you that, I think, but you have to be patient. I'm in a renovation and have no access to my NAS. I think until the begin of June.
Thank you, I'm looking forward to it)
Good afternoon. I remind myself. Thank you.
Today I got a box from storage, and I still don't have my NAS540, but I have my NAS520 back now. I think the 2nd stage bootloader is identical, as according to 'strings' it contains the same timestamp (uloader 2011.06.0 (May 20 2014 - 16:36:41)) as the one from NAS540.
Anyway, I PM'ed you a download link.
Thank you for the file, but it only contains the
uloader
part, which is exactly the same as mine.SPI:
0x000000000000–0x000000040000 : "uloader"
0x000000040000–0x0000000c0000 : "barebox"
0x0000000c0000–0x000000100000 : "env"My issue is specifically with
barebox
The logs show thatbarebox
is copied from SPI but does not start.
You only sent theuloader
part. As I understand it, my problem is withbarebox
.Please send the full image.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
