NAS540 with invalid superblock metadata
I have a NAS540 with 4 HDDs in RAID 5 configuration. The volume became inaccessible one day, and I've been doing a lot of things on my own, almost certainly incorrectly to repair the volume. I wasn't able to use the UI to auto repair the volume (it simply shows a red state that says "crashed"). I'd like to just be able to mount the volume to recover the data on it.
First, here's the current state of mdadm —examine:
BusyBox v1.19.4 (2024-01-02 11:31:49 CST) built-in shell (ash) Enter 'help' for a list of built-in commands. ~ # mdadm --examine /dev/sd[abcdef]3 /dev/sda3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 3014c29a:f2f02714:f899863e:15183df1 Name : NAS540:2 (local to host NAS540) Creation Time : Wed Jun 11 13:39:11 2025 Raid Level : raid5 Raid Devices : 4 Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB) Array Size : 5848150464 (5577.23 GiB 5988.51 GB) Used Dev Size : 3898766976 (1859.08 GiB 1996.17 GB) Data Offset : 262144 sectors Super Offset : 8 sectors State : clean Device UUID : acddab92:079d5458:b960a2a7:1306373c Update Time : Wed Jun 11 13:39:11 2025 Checksum : 5f9f75c7 - correct Events : 0 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 0 Array State : AAAA ('A' == active, '.' == missing) /dev/sdb3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 3014c29a:f2f02714:f899863e:15183df1 Name : NAS540:2 (local to host NAS540) Creation Time : Wed Jun 11 13:39:11 2025 Raid Level : raid5 Raid Devices : 4 Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB) Array Size : 5848150464 (5577.23 GiB 5988.51 GB) Used Dev Size : 3898766976 (1859.08 GiB 1996.17 GB) Data Offset : 262144 sectors Super Offset : 8 sectors State : clean Device UUID : a3c1c99a:1703ca51:22c84f0f:17cc7c0c Update Time : Wed Jun 11 13:39:11 2025 Checksum : 9925ed3b - correct Events : 0 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 1 Array State : AAAA ('A' == active, '.' == missing) /dev/sdc3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 3014c29a:f2f02714:f899863e:15183df1 Name : NAS540:2 (local to host NAS540) Creation Time : Wed Jun 11 13:39:11 2025 Raid Level : raid5 Raid Devices : 4 Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB) Array Size : 5848150464 (5577.23 GiB 5988.51 GB) Used Dev Size : 3898766976 (1859.08 GiB 1996.17 GB) Data Offset : 262144 sectors Super Offset : 8 sectors State : clean Device UUID : 2f3e3324:246a273f:a9723e9c:72ef33fb Update Time : Wed Jun 11 13:39:11 2025 Checksum : 8b929eb8 - correct Events : 0 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 2 Array State : AAAA ('A' == active, '.' == missing) mdadm: No md superblock detected on /dev/sdd3. mdadm: cannot open /dev/sde3: No such device or address mdadm: cannot open /dev/sdf3: No such device or address
In the process of recovery, I've ran a lot of commands including recreating partitions to zeroing out superblocks and recreating the array from scratch. Here is the output of /proc/mdstat before I messed everything up:
~ # cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md2 : active raid5 sda3[0](F) sdc3[2] sdb3[5] 5848151040 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/2] [_UU_] md1 : active raid1 sda2[0] sdd2[4] sdc2[2] sdb2[5] 1998784 blocks super 1.2 [4/4] [UUUU] md0 : active raid1 sdd1[4] sda1[0] sdc1[2] sdb1[5] 1997760 blocks super 1.2 [4/4] [UUUU] ~ # mdadm --examine /dev/sd[abcdef]3 /dev/sda3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 99545e30:aeecb506:7cc2e30b:3d610e47 Name : NAS540:2 (local to host NAS540) Creation Time : Wed Sep 13 08:36:34 2017 Raid Level : raid5 Raid Devices : 4 Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB) Array Size : 5848151040 (5577.23 GiB 5988.51 GB) Data Offset : 262144 sectors Super Offset : 8 sectors State : active Device UUID : a0d3cf94:05f63236:82af1e22:5e088985 Update Time : Sat Jun 7 11:55:02 2025 Checksum : 9fefda44 - correct Events : 3235 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 0 Array State : AAA. ('A' == active, '.' == missing) /dev/sdb3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 99545e30:aeecb506:7cc2e30b:3d610e47 Name : NAS540:2 (local to host NAS540) Creation Time : Wed Sep 13 08:36:34 2017 Raid Level : raid5 Raid Devices : 4 Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB) Array Size : 5848151040 (5577.23 GiB 5988.51 GB) Data Offset : 262144 sectors Super Offset : 8 sectors State : clean Device UUID : 05e17a13:d73cc4c8:ffbffc79:cb193407 Update Time : Sat Jun 7 12:04:41 2025 Checksum : 8ab652b7 - correct Events : 3247 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 1 Array State : .AA. ('A' == active, '.' == missing) /dev/sdc3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 99545e30:aeecb506:7cc2e30b:3d610e47 Name : NAS540:2 (local to host NAS540) Creation Time : Wed Sep 13 08:36:34 2017 Raid Level : raid5 Raid Devices : 4 Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB) Array Size : 5848151040 (5577.23 GiB 5988.51 GB) Data Offset : 262144 sectors Super Offset : 8 sectors State : clean Device UUID : 8118ef94:89977da0:25be3321:0b956784 Update Time : Sat Jun 7 12:04:41 2025 Checksum : 84e5e39 - correct Events : 3247 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 2 Array State : .AA. ('A' == active, '.' == missing) /dev/sdd3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 99545e30:aeecb506:7cc2e30b:3d610e47 Name : NAS540:2 (local to host NAS540) Creation Time : Wed Sep 13 08:36:34 2017 Raid Level : raid5 Raid Devices : 4 Avail Dev Size : 3898767360 (1859.08 GiB 1996.17 GB) Array Size : 5848151040 (5577.23 GiB 5988.51 GB) Data Offset : 262144 sectors Super Offset : 8 sectors State : active Device UUID : 703927dd:f56dd1f6:05a94b5b:e0be3252 Update Time : Fri May 30 13:11:50 2025 Checksum : aeb0ecda - correct Events : 2938 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 3 Array State : AAAA ('A' == active, '.' == missing) mdadm: cannot open /dev/sde3: No such device or address mdadm: cannot open /dev/sdf3: No such device or address
As you can see, it's possible that /sdd3 is severely degraded while /sda3 is close to it, based on the stale event count.
First thing I tried is to just create the array with all 4 drives. It fails due to IO error on /sdd3:
~ # mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2 --chunk=64K --layout=left-symmetric /dev/md2 /dev/sda3 /dev/sdb3 /dev/sdc3 /dev/sdd3
mdadm: /dev/sda3 appears to be part of a raid array:
level=raid5 devices=4 ctime=Wed Jun 11 13:39:11 2025
mdadm: /dev/sdb3 appears to be part of a raid array:
mdadm: /dev/sdc3 appears to be part of a raid array:
Continue creating array? yes
mdadm: Failed to write metadata to /dev/sdd3
~ # dmesg | tail
[ 2422.428266] sd 3:0:0:0: [sdd] CDB: cdb[0]=0x28: 28 00 00 3d 07 f0 00 00 08 00
[ 2422.435562] end_request: I/O error, dev sdd, sector 3999728
[ 2422.441307] sd 3:0:0:0: [sdd] Unhandled error code
[ 2422.446126] sd 3:0:0:0: [sdd] Result: hostbyte=0x04 driverbyte=0x00
[ 2422.452511] sd 3:0:0:0: [sdd] CDB: cdb[0]=0x28: 28 00 00 00 08 00 00 00 01 00
[ 2422.459813] end_request: I/O error, dev sdd, sector 2048
[ 2422.465249] sd 3:0:0:0: [sdd] Unhandled error code
[ 2422.470066] sd 3:0:0:0: [sdd] Result: hostbyte=0x04 driverbyte=0x00
[ 2422.476457] sd 3:0:0:0: [sdd] CDB: cdb[0]=0x28: 28 00 00 00 08 00 00 00 01 00
[ 2422.483749] end_request: I/O error, dev sdd, sector 2048
Next, I've tried to recreate the array with the 4th failing drive excluded. However, mounting fails:
~ # mdadm --create --assume-clean --level=5 --raid-devices=4 --metadata=1.2 --chunk=64K --layout=left-symmetric /dev/md2 /dev/sda3 /dev/sdb3 /dev/sdc3 missing mdadm: /dev/sda3 appears to be part of a raid array: level=raid5 devices=4 ctime=Wed Jun 11 13:50:24 2025 mdadm: /dev/sdb3 appears to be part of a raid array: level=raid5 devices=4 ctime=Wed Jun 11 13:50:24 2025 mdadm: /dev/sdc3 appears to be part of a raid array: level=raid5 devices=4 ctime=Wed Jun 11 13:50:24 2025 Continue creating array? yes mdadm: array /dev/md2 started. ~ # mkdir /mnt/recovery ~ # mount /dev/md2 /mnt/recovery mount: wrong fs type, bad option, bad superblock on /dev/md2, missing codepage or helper program, or other error In some cases useful info is found in syslog - try dmesg | tail or so. ~ # dmesg | tail [ 2533.802943] md/raid:md2: allocated 4220kB [ 2533.807051] md/raid:md2: raid level 5 active with 3 out of 4 devices, algorithm 2 [ 2533.814554] RAID conf printout: [ 2533.814559] --- level:5 rd:4 wd:3 [ 2533.814566] disk 0, o:1, dev:sda3 [ 2533.814571] disk 1, o:1, dev:sdb3 [ 2533.814577] disk 2, o:1, dev:sdc3 [ 2533.814682] md2: detected capacity change from 0 to 5988506075136 [ 2533.824985] md2: unknown partition table [ 2556.944048] EXT4-fs (md2): bad geometry: block count 1462037760 exceeds size of device (1462037616 blocks)
There appears to be a discrepancy in sizes reported by superblock and the physical size. Running e2fsck shows the following:
~ # e2fsck -n /dev/md2 e2fsck 1.42.12 (29-Aug-2014) The filesystem size (according to the superblock) is 1462037760 blocks The physical size of the device is 1462037616 blocks Either the superblock or the partition table is likely to be corrupt! Abort? no /dev/md2 contains a file system with errors, check forced. Pass 1: Checking inodes, blocks, and sizes Error reading block 628 (Attempt to read block from filesystem resulted in short read). Ignore error? no Error while iterating over blocks in inode 7: Attempt to read block from filesystem resulted in short read e2fsck: aborted
I'm not really sure how to proceed from here. Any guidance would be really appreciated. I don't need full recovery — a partial recovery of the data would also go a long way.
This emits some questions. Your current array has array state AAAA, while /dev/sdd3 has no superblock, and mdadm got an I/O error on sdd. Any idea how that is possible?
And then on the current problem. The original array had:
The current array has:
So the array size shrunk from 5848151040 KiB to 5848150464 KiB, due to not fully using the Dev Size.
Then the mount:EXT4-fs (md2): bad geometry: block count 1462037760 exceeds size of device (1462037616 blocks)
One block is 4096 bytes, which is 4KiB, so the message translates to
bad geometry: 5848151040 KiB exceeds size of device (5848150464 KiB)
Looks familiar? So to solve this issue, you have to force the use of the total available Dev Size. Maybe
mdadm --grow /dev/md2 --size=max
will do the trick.
This is worrying. Did you look at the kernel log? This is probably an I/O error on one of the disks, but I can't predict which disk. It can be necessary to make a low level copy of the faulty disk in order to be able to copy the data. (A unreadable block on a key position can be very disturbing). Do not run e2fsck on bad disks, it could make things worse.
did the trick! I'm able to mount the volume with the 3 drives, and I'm able to copy the files off. Thank you!0
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 440 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 84 About Community
- 91 Security Highlight
