Firewall disconnected from SecuReporter
GiuseppeR
GiuseppeR Posts: 505 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
edited March 18 in Nebula
Hello everyone,
I manage a Flex100 that suddenly disconnected from SecuReporter.
It is strange because it is online:
Its settings are OK:
Anyway this is the welcome page on SecuReporter:
Is it possible that this device, renamed from one site to another one with different configs but inside the same Organization, encountered a bug on SecuReporter data provisioning?
Having SecuReporter working properly is essential.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,938 image  Guru Member
    Update:
    The issue is due to misconfiguration on connectivity check on WAN interface, fix the misconfiguration fix this issue.
    Zyxel Melen
  • Zyxel_Melen
    edited March 19
    Hi @GiuseppeR,
    I checked with our engineer that this issue needs to access your organization. Could you enable Zyxel support access so our engineer can check this issue? Also, please share the org name and the timestamp of this issue that occurred with us.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    you have the access to that Organization, you find Case 250301974 open for you.
    See you soon
  • Zyxel_Melen
    Update:
    Zyxel Melen
  • GiuseppeR
    I can confirm what @Zyxel_Melen wrote.
    It was a misconfiguration with connectivity check option inside WAN details, the firewall was looking for a non-existent IP.
Nebula Tips & Tricks
