[NEBULA] Spotify Whitelist Content Filter
we activated the Content Filter on our Nebula Control Center. I added many options to it and now spotify does not work anymore. I added spotify.com and open.spotify.com to our whitelist.
What do i have to config that the Desktop App works?
Hi @jlu
Welcome to the Nebula community!
Believe the stream and download category has block your Spotify stream.
Can you please add *.spotify.com to your white list instead of the current setting and please also unplug your cable for a few seconds then plug-in.
Cheers!~
Chris0 -
Hi Chris, i tried it but it does still not work.0
May you able to visit and listen to Spotify(play.spotify.com) via your browser?
I just see the discussion in the Spotify forum.
https://community.spotify.com/t5/Desktop-Windows/A-firewall-may-be-blocking-Spotify-Please-update-your-firewall/td-p/4506619
One of the solution is to correct the country setting of your account.
Maybe you also need to change it to make desktop app works.0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
