VLAN
I have a big problem. I have create a vlan, but I cannot use it. If I set my IP in fix IP, does'n't work. DHCP is activate and I can ping gateway of VLAN… We say to me "untag/tag port"… I don't no where is the menu…
Can you help me
Hi @JalitiQ,
Thanks for your question!
From what you described, it seems that your VLAN interface is working properly — since DHCP works and you are able to ping the VLAN gateway when your device (eg. PC) gets an IP automatically.
However, when you set a static IP, it doesn't work, and you mentioned you're looking for tagged/untagged port settings. In this case, I suspect the issue might be related to the switch port connected to your device not being configured correctly for VLAN traffic.
If that's the case, could you kindly provide your full network topology and the model names of the devices involved? This would help us give you more accurate guidance.
In the meantime, here is an article on configuring port and VLAN settings on a switch, in case you would like to try some initial adjustments on your own.
Zyxel Tina
Hi @JalitiQ,
Zyxel Tina
I think you mean can't ping gateway of VLAN?
Do you have a PC to the USG or switch? How is the switch setup?
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
