Strange widget values: "Access points by usage" VS. "Access point clients by usage"
Hello everyone,
I have a site with a security router + 2 APs.
If I look at these two widgets I see huge difference in value:
Both of them are summarizing last 24h but on the left you see only 7 MB of usage.
Does "access point by usage" include also traffic spent via security router?
Hi @GiuseppeR
Yes, we have this in our feature request list.
Also, I create an idea post. We will monitor the comments and vote to evaluate this idea.
Zyxel Melen0
Hi @GiuseppeR,
Access point by usage isn't include the wireless traffic on security router.
Comparing with our field trial network's dashboard, it is strange that the Access points by usage > Traffic value is smaller than the top of client in Access point clients by usage.
May I know if the issue remains? If so, please help to enable Zyxel support access, we will access to check this issue.
Zyxel Melen0 -
Hi @GiuseppeR
Since your topology is USG Lite 60AX as mesh root and NWA50AX PRO as mesh repeater, this will cause the Access points by usage widget displays less than expected.
After checking, this is the "Access points by usage" widget only trace the traffic passing the uplink. If the traffic is between the same AP same SSID or the AP uplink is USG Lite 60AX (mesh root), the traffic will not be recorded in this widget.
Zyxel Melen0 -
Hello @Zyxel_Melen
do you plan to fix that detail considering USG 60AX mesh capabilities?
It could be useful to read that value properly, like if the AP was going to internet via RJ45 and not via mesh
Hi @GiuseppeR
Zyxel Melen0 -
Hello @Zyxel_Melen
thanks a lot for this update. I liked the idea post too, of course.
Hi @Zyxel_Melen
I updated USG LITE 60AX to V2.30(ACIP.1) but I still see the lack of traffic infos on the widget when having all the APs as mesh network:
So having this topology:
Is still an issue to have the possibility to monitor the network traffic?
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
