Display order in the SSID list
TipoTimido
TipoTimido Posts: 32 image  Freshman Member
Sorry, I really don't understand what order this list of SSIDs follows in the Client Policy rules. But I confirm that it "DOES NOT" follow the order of SSIDs that I created in Configure -> Access Point -> SSID Settings like below
Them are two different display order and this way I can't figure out which SSID I'm blocking or not in client policies.
Anyone can help me to understand How to understand which access point the listed SSIDs refer to in the first image?
  • TipoTimido
    edited June 25
    It would be nice if in addition to the SSID you also showed the AP it is associated with by the SSID.
    Becouse in this situation, i'm very confused and can't figure out which SSID select for specific devices in the building:
  • TipoTimido
    here i found the display order and i can confirm that it do not respect the creation order, but it set a his order without rule:
    and for confermation, inside every index we can find SSID name and AP associated:
    Can you put the AP name in the policy list so we know what we are managing?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @TipoTimido ,
    As you observed, currently there is no specific order for the SSID list in Client > Policy. We'll evaluate this feature.
    By the way, could you share why you need to configure several SSIDs with the same name?
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @TipoTimido ,
    The AP that clients connect to can be checked in the Connected to column. Since the policy is not related to the AP, no AP information is displayed in the Policy function.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
