How get supervisor od root password of NR7103 modem?
123457»
  • Arona
    Arona Posts: 25  Freshman Member
    can i have the supervisor password of a nr7101?
    serial: S/N: S220Z40007964
    thanks
  • hwv8
    hwv8 Posts: 2  Freshman Member
    Hello!
    Since none the algos worked for getting the supervisor password for my NR7101 I was told that here somone could help me with the password. Serial is S220Z08004013
    Many thanks in advance,
    Winnie
  • hwv8
    No one?
  • JM25
    JM25 Posts: 2  Freshman Member
    I have a AX7501-B1 router, i would like the root/supervisor password.
    SN: S220Y51025057
    Thanks a lot!!!
  • lartzzz
    lartzzz Posts: 2  Freshman Member
    Good evening peeps!
    I'm trying to get into "my" Zyxel NR7103, bought from "Tre" in Sweden.
    No luck with zyxel_pwgen to solve root/supervisor. Can someone help, plz?
    S/N: S220Z04004359
    / Lars
  • amir
    amir Posts: 2  Freshman Member
    Hi. I have an NR7103 that has not been in use for a couple of years. Recently I decided to use it again, but I couldn't find the PoE that had a sticker on it (I don't remember what it was for—maybe the Wi-Fi password). I bought a new PoE, but now I can't access anything, neither via Wi-Fi (impossible to recall the password) nor LAN (no IP allocation). What should I do?
