configure address object
ptditservices
ptditservices Posts: 1 image  Freshman Member
Third Anniversary
  • Zyxel_Tina
    Zyxel_Tina Posts: 717 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @ptditservices,
    Based on your post title, it seems you're asking how to configure address objects on our firewalls using the Nebula Control Center. The method for this depends on your specific device model.
    1. For ATP/USG FLEX Series: When managed by Nebula, these models do not support objects in the same way as standalone firewalls. Instead of creating objects, you can directly enter the IP address and service port in the security policy during configuration.
    2. For USG FLEX H Series: This feature is supported. The following FAQ can guide you on how to manage address objects on Nebula: Managing USG FLEX H Series Objects on NCC — Zyxel Community
    If this doesn't answer your question, please feel free to provide more details about your specific goal. Knowing your device model and what you are trying to achieve will help us assist you better.
    Zyxel Tina
  • Zyxel_Tina
    Hi @ptditservices,
    Zyxel Tina
Nebula Tips & Tricks
