Zyxel USG 100
gudoule
gudoule Posts: 3 image  Freshman Member
How to solve issue
Cli Number :0
Error number: -2
Error Message: Not connected to ZySH Daemon
Best regards
  • Zyxel_Tina
    Zyxel_Tina Posts: 697 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @gudoule,
    Firstly, we would like to confirm whether your device is a USG 100 and not a USG Flex 100. If this is correct, please note that the Zyxel USG 100 is an End-of-Life (EOL) product, with support having ended on June 30, 2018.
    Regarding the problem you are encountering, could you please try the following steps:
    1. Reboot the device — This often resolves temporary system module failures.
    2. Check firmware version — What is the current firmware version of your USG 100? If it is not running Firmware_3.30(AQQ.7)C0, please update it to this version. I will provide the firmware to you via PM.
    If the issue persists, we strongly recommend considering an upgrade to a newer security device, such as USG Flex 100H/USG Flex 100.
    Zyxel Tina
  • gudoule
    Firewall is a usg flex 100 i try to update software with firmware 540ABUH0C0.bin. I use ftp method, but when i reboot i always have the alert windows with the message
    Best regards
  • Zyxel_Tina
    Hi @gudoule,
    To better understand the situation and provide more accurate assistance, could you please help share the following:
    1. A detailed description of the sequence of events, for example,
      • Where does the error appear?
      • When does the error appear?
    2. A diagnostic file from the device
      • If the web GUI is accessible, please send it to us via private message
      • You can refer to this FAQ for instructions on how to collect the diagnostic file
    This will help us guide you more effectively. Thank you!
    Zyxel Tina
