fail over wan
is there a way to check through the API the connectivity of the second wan connection? Like an ping through this specific port or something like that.
Hi @Dpj
USG FLEX 50H supports wan fail over, you will need to set it in the interface trunk function. You may access the device's local GUI to set it.
https://jam.dev/c/22a29032-3671-426a-92ea-c7f791cc8184
Nebula currently not support the interface trunk function. It is in our feature list, but the schedule is TBD.
Zyxel Melen0 -
Hi @Dpj
May I know this request is to use API to set connectitivty check or triger a ping test?
Zyxel Melen0 -
I realy hope in the future it will be possible to edit more settings through the API. Just for example Create Security Policies, Nat Rules, Set Fail over Wan. etc. (but set an connectivity check would also be nice). At this moment it's more asking to nebula what do you have for me instead of creating / changing settings. But to come back to your question, it was now to ping through an specific interface.
Today i got the question: For example, we find an issue with our used configuration, and we have lik 300 customers. with all the same hardware. (just example). How can we push new settings to all customers, instead of going through all the customers one by one.
For that the API would be great. But for now the only posibility i think is to go one by one through all the customers.0 -
Hi @Dpj
Nebula API for ping currently not support to select specific interface. We have created an idea post for this requirement.
Nebula open API support ping option for specific interface — Zyxel Community
Development is in progress for the set/configure API. Thank you for your patience as we make progress. Stay tuned for more updates soon!
Zyxel Melen0
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 300 Service & License
- 483 News and Release
