Zyxel USG 100
Hi @gudoule,
Firstly, we would like to confirm whether your device is a USG 100 and not a USG Flex 100. If this is correct, please note that the Zyxel USG 100 is an End-of-Life (EOL) product, with support having ended on June 30, 2018.
Regarding the problem you are encountering, could you please try the following steps:
- Reboot the device — This often resolves temporary system module failures.
- Check firmware version — What is the current firmware version of your USG 100? If it is not running Firmware_3.30(AQQ.7)C0, please update it to this version. I will provide the firmware to you via PM.
If the issue persists, we strongly recommend considering an upgrade to a newer security device, such as USG Flex 100H/USG Flex 100.
Zyxel Tina
Firewall is a usg flex 100 i try to update software with firmware 540ABUH0C0.bin. I use ftp method, but when i reboot i always have the alert windows with the message
Error Message: Not connected to ZySH Daemon
Best regards
Hi @gudoule,
To better understand the situation and provide more accurate assistance, could you please help share the following:
- A detailed description of the sequence of events, for example,
- Where does the error appear?
- When does the error appear?
- A diagnostic file from the device
- If the web GUI is accessible, please send it to us via private message
- You can refer to this FAQ for instructions on how to collect the diagnostic file
This will help us guide you more effectively. Thank you!
Zyxel Tina
0 - A detailed description of the sequence of events, for example,
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 501 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
