USG FLEX PPPoE Connect
WhoYouNow
WhoYouNow Posts: 10 image  Freshman Member
Hello! I encountered a problem with the PPPoE connection on the USG FLEX 700H router
I chose port 3 as a test port and configured the VLAN 20 configuration + username and password on it. But the equipment did not receive any DHCP address
Can you tell me how to analyze the problem and find a solution for the connection?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @WhoYouNow
    Let me provide you with the steps via the device's local GUI.
    1. Please navigate to Menu > Network > Interface > Interface > External interface to add a new VLAN interface with PPPoE. Below is the example. image.png
    2. Once you set, you will see the VLAN interface with PPP interface. image.png
    Zyxel Melen
  • WhoYouNow
  • Zyxel_Melen
    Hi @WhoYouNow
    May I clarify something first?
    1. Is your USG FLEX 700H online on Nebula when you testing? If it is offline, you will need to access the device's local GUI to set the configuration.
    2. Is the port status of port 3 linked up?
    3. Can you access the firewall's local GUI to check the configuration is set? Path: Menu > Network > Interface > External.
    4. Please check the PPPoE configuration is the same as your ISP recommend configuration. Like change to VLAN832.
    5. Please check the event log to find the reason you can't connect PPPoE.
    Zyxel Melen
  • WhoYouNow
    edited July 2025
    Good afternoon! Thanks for the answer!
    1. Yes, my FLEX 700 is online, through a second provider
    2. Port 3 is connected to the equipment of the PPPoE provider and physically connected by a wire
    3. I will try your advice
    4. Tell me the setting point where I can choose VLAN832? (maybe a screenshot)
    5. I will look at the log
  • Zyxel_Melen
    Hi @WhoYouNow
    Zyxel Melen
  • WhoYouNow
    It work, thank u
Nebula Tips & Tricks
