Replace ATP200 with Flex200H
If I replace my Nebula ATP200 firewall with a Flex 200H, will it copy the settings over, or will I need to start from scratch?
Hi @TAPTech,
Unfortunately, because your ATP200 and USG Flex 200H are managed by Nebula, direct configuration migration using a converter tool is not supported for this specific scenario. You will need to manually reconfigure the settings on your USG Flex 200H. Thank you for your understanding.
Zyxel Tina
Check the conversion tool
Thank you for the tip. I checked the conversion tool, however both of the Firewalls are on Nebula. It looks like the conversion tool is only for local/non-cloud.
Hi @TAPTech,
Zyxel Tina
Hi Tina,
Here is how I made it a bit easy- created a new Site in Nebula with the USGFlex200H and copied over the settings. Once the settings were complete, I move the switches and access points to the new site, then deleted the old site.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
