FWA710 will occasionally Port down and up within a few seconds
phayze
I found out that my FWA710 will occasionally port down and up within a few seconds. It is powered by the PoE injector that come with it. While it does not cause any notification on connectivity check as it a just a few seconds, any idea if this is normal?
It could happen when there's an update in WAN IP address.
Regards,
Bob
My FWA710 is now doing this and it is interfering with any online meetings. Is there any way to fix it?
Hi @ggghhh
May I clarify:
- Is the PoE switch/injector working properly?
- Which mode are you using?
- What's the frequency of this issue?
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
