blocked by key handshake fail - Iphone 16 - IOS
2»
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    Hi @venom
    Thanks for your update! We will wait for your next update and keep clarifing this issue.
    Zyxel Melen
  • venom
    venom Posts: 8  Freshman Member
    edited July 18
    —download by Zyxel Melen—
    Hello @Zyxel_Melen
    I have the same problem after resetting the network settings and with the Zyxel APs in WPA3.
    Test 2 doesn't seem necessary because I only use an SSID on Zyxel AP
    For test 3, I downloaded the debug, see attached
    The screenshot shows the times with errors.
  • Zyxel_Melen
    edited July 18
    Hi @venom
    Thanks for the file. We are investigating on it and will update you once I have further information.
    Zyxel Melen
Nebula Tips & Tricks
