WLAN Settings Access Issue
anashoff
anashoff Posts: 1 image  Freshman Member
I’m trying to access WLAN Settings on my USG FLEX 500H device, but I get a blank screen with a loading symbol.
How can I access WLAN management?
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 397 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @anashoff,
    Typically, it takes a little time for the system to load the data and display it.
    Regardless of how, I would like to invite you to enable support access for the Org with us.
    Please let me know the name of the organization and the account/password for the device GUI in a private message, so we can help to check this issue.
    Thanks.
    Ivan
  • Zyxel_Ivan
    Hi @anashoff,
    The issue was solved after you updated the firmware to version 1.35.
    Thanks.
    Ivan
