Nas 326 non riesco a vedere le cartelle
Giuseppe_AIELLO
Salve.
Ho 4 nas 326 connessi alla rete che funzionano perfettamente. L'ultimo installato configurato come tutti gli altri non mi fa vedere le cartelle video, foto, ecc.
Quando mi collego attraverso il suo ip vedo una schermata vuota.
Avete idea di quale possa essere il problema?
Grazie
Does the webinterface work? And can you access the data using the filebrowser in the webinterface? In that case the samba server is b0rked, and a factory reset might help.
Yes. Te interface work. Disk is empy because is new installation. I have 4 other same nas that work in the same network with same settings. I tray to reset and re setting but same result. Any suggestion? Thanks
Solved.
Delete created volume and recreated it. Now work
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
