[NR7302] DHCP renewal fails on IP pass-through
I'm operating a NR7302 on a Telekom 5G network in pass-through mode. The router is an OpenWRT device.
The interface is set to renew the lease from time to time, but when this happens, the renewal fails and a new lease is requested. This leads to an interruption of appr. 10 seconds.
Here is the tcpdump when a renewal is happening.
As you can see, the renewal request is denied ("NACK" / "lease not found"), so the router starts a new discovery.
Is this a known issue, or maybe some kind of misconfiguration on my side?
OK, got it solved, with only a minimum of mystery left. I had to enable the ARP Proxy, now the renewals are transferred correctly between the router and the APN.
The only mystery left is the default lease time value with 0. Is it always 24h or derived from the ISP's DHCP server? Given the request above, the latter doesn't seem to be the case.
This might be your ISP doing when they change the 10. IP if they change it every so many hours
IP pass-through is not a true interaction with the ISP gateway instead the NR7302 acks as a proxy 1:1 not NAT so you get the IP you would of got by true interaction with the gateway.
One of the problems thats posted here is Zyxel lease can be longer then the real lease and so you may lose connection
https://community.zyxel.com/en/discussion/25880/feature-request-immediate-dhcp-renewal-for-ip-passthrough-mode#latestIt would be best if Zyxel can relay the lease time the ISP is doing.
Did you change the Lease-Time?
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
